Can you run two reversible pumps off the same thru-hull intake? If you put a valve and a T on the intake then connect two reversibles, would there be any issues filling or draining if you only ran one of the pumps at a time? I originally thought that when draining, it would push water up the other pump, but I think the impeller acts like a check valve.
