03 LSV
part # and any idea where to buy online?
the rubber flaps that cover the exhaust under the swim deck came off this weekend. well one did, the other is on its last leg.:(
03 LSV
try your local dealer if you have one. you need to buy a set of 4" exhaust flappers. pretty basic stock item. save the one you take off. you then need to cut the round part that the hose clamp clamps down to 3.5".
I saw prices that ranged from $29-45 for a pair online. went to my local dealer(actually mastercraft dealer cause they were closer) and bought a pair for $28 plus tax.
once you open the new 4" one and take the old 3.5" one off, you will see how to cut/install it.. make sure you use the correct hoseclamp, not the 4" ones that come with the new ones :)
http://www.bakesonline.com/images/20...Grd4inchSM.jpg
so the pipe is 3.5"
why dont they just sell 3.5" that fit?
they only make the flappers in 3" and 4". skiers has opted to use a 3.5" pipe. not sure why, but interestingly enough you look at a $75k brand new launch24ssv and it's the same way.
it's real easy to cut it down and get it to fit, and if you take a few minutes and make sure you have a good, sharp utility knife, you can really make it look like it's a 3.5" piece from distances more than a foot away..
One of the many small things that should be changed, however I am sure that with the state of business, guess I'd rather see engineers working on the "big" things..
oh ya, and when cutting it, I got the best results cutting at the bottom of the clamped part, not up near where the flapper is molded to the mounting ring. you don't have to modify the flapper part at all, and it is easier to install with the wakeplate all the way down. gives you a little more room to work. adjust it before crawling under the swimdeck in the garage :)
these were the best deals i could find online
$9.95
http://us.binnacle.com/product_info....oducts_id=2320
$15 shipping
$18
http://www.macombmarineparts.com/pro...ducts_id/12686
$12 shipping
i ordered from the binnacle site and it came to $35 shipped for the pair
not a bad price. good luck with the repair....
Because this technology is as old as a set of points and condenser. I get mine at a local Marine Dealer (keep in mind I am surrounded by thousands of offshore boats here) and that is the way they always came and it is an accepted and standard practice to "cut to fit" whatever you are putting them on. I also didn't pay much for them at all, I believe it was less than 10 bucks each and they have a funny name for them but I forgot it.
In the platform oil aisle.
