Ignition Switch, need some help
2000 Moomba Mob V
Hey guys, I screwed up. I was unhooking my depth finder to pull it out of the boat to clean it up, inside screen was dirty. Anyway, I pulled off a red wire from the switch panel on accident, it was still attached to the ignition switch, just not the circuit board behind the switch panel.
This red wire went to the ignition switch and I'm not sure where it hooked up to the panel at. I thought I found it but every time I hook it up to that the fuel pump kicks in, like you just turned the key on. It will start, but turning the key off does nothing. I have a blue wire, yellow w/ red wire, and the red wire I mentioned as the 3 wires going to the switch. Anybody have a schematic or picture of their ignition switch and what wires go where?
Need to get this figured out by Friday so I can get back on the water, with a working ignition switch. Please help, thanks.
