How different is it than a truck?
I've got a '05 Outback with seemingly the same problem.
Do you guys know the answer to any of the following:
1) How many relays are in a Moomba ignition system. The reason I ask is that I had an old pathfinder with the same problem and only after replacing the starter did I learn that there were actually two relay solenoids (rather than a CJ-7's 1) that worked to fire the starter. That day ended with an uncommon amount of rage and shame on my part and I wanted to double check before making that same mistake twice.
2) How easy is "easy" when replacing a starter on an Outback. In truth, I haven't looked at it very hard (had a boat full of people at the dock and was more interested in developing fall back Sunday plans that a full diagnosis). Are all the bolts accessible or do you have to do a lot of deconstructing to get to those needed to drop the starter?
Thanks very much in advance,
A
