I need to raise the height of my Helix driver's seat?
I bought a new '17 Helix a few weeks ago and the driver seat is not tall enough for the wife to see over the windshield even with bolster seat flipped up. The foam in the cushion on the bolster is so dang soft it just compresses completely flat so it doesn't appear to do much to raise the seat height. I'm wondering if there is a way to change out the bottom riser to a little bit taller one and then just slip the seat assembly back onto the riser? Anyone else done this to another Moomba or a Helix specifically and maybe have a part number or a website to get one from?
It shouldn’t be too hard since the boat isn’t old. I helped replace the riser on my soon to be father in laws older chaparral last summer and the two front screws were in threaded inserts, corrosion over the years had seized them up good. I brought up a micro torch and a big snap on screwdriver and got them out. All other screws were in the wood and came right out. This was a worst case scenario and it still only took a few minutes.
On a side note I just ordered this for our max that’s on order:
Garelick/Eez-In 75635:01 Blue Water Adjustable Height Ribbed Series Positive Pin Lock Pedestal - 12" - 17" https://www.amazon.com/dp/B002IR20YW..._Zsi7AbFJQRFEC
When I’m towing I want to be able to see over the 5% tinted windshield without using the seat bolster, and this is adjustable so the fiancé can find a setting she likes as well. On my old boat I’d end up sitting on the bolster but hunched over (since there wasn’t any back support) which would kill my back after a while.
