Figured I should just start a new thread instead of continuing hijack Larry's review of the Supra thruster.
I picked up a sideshift stern thruster for my Makai on Black Friday last year. My comments below on how it is performing so far copied below from the other thread.
"I added a thruster to my Makai. Not the same system as on the Supras so cant comment on the amount of thrust but it sounds similar. Enough to back straight up and slowly turn the boat on its axis in either direction.
As for the use cases I think all of the comments are spot on. I don't think it will help much to get back to your rider quicker. Turning the wheel opposite of your surfer (the surf tabs help) while coming off plane already kicks the boat around almost immediately so no need for a thruster there.
I do use it some once I get back to the surfer just to position the boat in the direction I want to go relative to the rider. Like mentioned, its not an issue for advanced riders but some of the younger ones and novices like to come up on the surf side and thruster makes that easier especially if it is windy or you want to switch directions and head back where you came from. My kids have also just started trying some dock starts on a wakeboard and it was really nice to be able to keep the boat aligned while bringing them the rope and easing out the slack.
Docking is great and I use it every time even if it is just to bump it for a second or two to make it slide in perfectly. Any slight mis-alignment that might previously have needed to be handled by your bumpers or dock hands is now easily adjusted for with the thruster.
Also love being able to back in a straight line or turn against the prop rotation. Backing into the beach is now easier and no more big sweeping 180's in reverse because I cant point the back of the boat where I want it to go.
Have been driving inboards for a really long time so definitely didn't need it but it sure is nice to have. Don't think I will ever own another boat without one."
