Retaining nut & coupling set screw question
I have an '04 mobius and I am replacing my shaft seal. When removing the retaining nut from from shaft I noticed that it was not very tight. When reinstalling everything back, I tightened the nut to shaft (read it needs to be 60 - 70 ft/lbs) and the set screw. Problem is that the set screw completely misses the retaining nut now.
Do I need not tighten retaining nut as tight or can I add a washer between coupling and nut so set screw is on the retaining nut? Thanks!
