Hi i wondering what type of oils for vdrive and tranny for 2017 moomba craz ?
The info is in the Operator's Manual. The shifting portion of the transmission, with the red dipstick, uses Dexron 3 or Dexron 6 automatic transmission fluid. The v-drive portion with the yellow dipstick uses Mobil Delvac 50 synthetic transmission oil like would be used in a standard shift transmission in a high performance car or heavy duty trick.
thanks you for the info.
Larry, sorry for the ignorant question without referencing the manual.....to change each of those, are there drain plugs or should Mx be done by vacuum pumping out the dipstick holes?
Can I use any different type of oil? Other than the Mobil Delvac 50 synthetic transmission oil in the vdrive portion?
2018 Max
I am curious about this too
Other manufacturers make SAE 50 synthetic manual transmission oil. Most are equally rated for 500k mile drain intervals when used for over the road trucks in severe conditions.
Amsoil, Delvac,Triax to name a few.
https://uploads.tapatalk-cdn.com/202...4375bc03e4.jpg
But no matter which brand it’s appx $50 per gallon.
Most come in gallons only, so this may be the one case to just get qts of the Indmar synthetic transmission fluid at $14 each from bakes.
Indmar is delvac SAE50
