Dual battery ... where to hook the amp?
So I've looked through the dual battery posts, but couldn't find an answer to this question.
I have a dual battery setup, running through a Perko switch. Battery 1 is my starting battery. Battery 2 is my deep cycle Optima accessory battery.
Right now, I have my amps wiring into battery 2. I always keep the Perko at the 1+2 setting, except for when we are floating. Then I put it on 2 so as to only drain the Optima battery.
My question is: should the amps be connected to the 2nd battery, or should they be wiring into the output of the Perko switch? I'm not sure if it even matters, but thought I'd see what everybody else is doing.
