Battery not charging 2008 lsv
Hello, I have a 2008 moomba möbius lsv. I am having a problem with batteries being charged off of my altinater. I have just replace the altinater and am still not receiving a charge. I can run a separate wire to my battery and get a charge. I was out on the water and my dashboard started beeping and flickering like their is a bad connection or a switch was going out then it just died. I have checked all the fuzes under the dash board and they are all good. Does any one know where the altinater power wires run along the boat or have any other advice on what I should do. I can make it work with a separate wire I just want to fix the problem before it gets worse.
Taylor
Sounds you have a bad and/or corroded connection somewhere based on your observations. Maybe at the alternator itself or at the battery terminals. Check both connections on positive and negative side.
Also check the battery switch to see if the contacts are corroded.
You have a bad connection from the alternator to the need to check the Voltage at every point along the way to the battery to find the interruption. Is there voltage on the main wire as it enters the perko switch?
