Can anyone tell me what these numbers translate too for the prop lol
Trying to find out my stock prop info. Talking to wakemakers they said they don't list the 03 moomba because they had a couple different sizes thatbyr? Any clue about that???
None. Are there any numbers on the face right under the nut? May have to remove the cotter pin and nut to view.
Couldn't see anything on the end. Def might have to remove the nut then. The cotter pins rusty as hell also so not to replace it anyway. The only bad thing is it's on our list right now lol. My luck I would drop the nut and its 30 feet deep under r lift HA
If you are not removing the prop you don't have to take the nut all the way off. Just loosen it until you can read the numbers then tighten back up and replace the cotter pin.
Awesome. will do. I'm sure I'll run up to the cabin sometime this week to get the boy some pulls. Thanks
Pulled the nut and nothing under the nut or the backside of the prop? So might call skierschoice with the hull ID and see if they could tell me what prop might be on this boat?
My guess would be an OJ 13"x13" or something pretty close. Is it a 3 blade? Any prop repair place can tell you the pitch. You can figure the diameter by measuring from the center to the outside edge of any fin and double it.
Quote:
Originally Posted by
kaneboats
I think they have always been 13x13 from the factory.
