Need Help Wiring!!
hi there guys, i have a 1800 watt kenwood amp and 2 10 inch punch dual voice coils subs. i would like someone help me with wiring them. i do not know a whole lot about ohms and stuff like that.
here is the link to the specs on my amp:
http://www.sonicelectronix.com/item_...mpaign=froogle
here is the link to the subs. i have 2 of them:
http://www.rockfordfosgate.com/produ...n_US&p_status=
thanks!!!
Wire each 2-ohm DVC sub in series, this will give you two 4 ohm subs. Then wire the two subs in parallel, this will give you a 2 ohm load at the amp for 900 watts rms.
Follow the link to your sub. Click on the wiring wizard tab. Follow the wiring configuration for two subs that results in a 2 ohm total load. This will deliver 450W rms to each sub so be careful with the volume since they are only rated 250W rms per sub.
