Does anybody have an exact picture showing where the impeller goes and tips to remove and replace
Sent from my SM-G920W8 using Tapatalk
Here are two pics that should give you what you need:
Attachment 25453
Attachment 25454
http://www.inboardonline.com/how-to/
https://forum.moomba.com/showthread....nging-impeller
https://forum.moomba.com/showthread....er-replacement
I use needle vise grip to remove it. to replace: put the impeller in the pump.....turn it in the good direction so the rubber fins go in the good direction.... tap it lightly with a rubber mallet until it goes in place put back the cover with the seal ( I tighten the screws in a way to have an equal pressure on the seal)..don t forget to put lube on the impeller
