2019 Mojo port ballast pump stuck on
This weekend I was out on the lake and the port ballast was acting up. The bag was constantly filing and if I could get it to drain it would fill again. I ended up getting the boat back to the lift and draining the bag by disconnecting the hose and draining with the center hull plug pulled. This is when I noticed that the pump running would not turn off unless the battery switch was off.
I've read some other post that seem to indicate that this is a relay switch issue and pulling the fuses can kill the pump. Has anyone else had this problem? Has anyone had any success with pulling the fuse to reset the relay? If I run the boat without the fuse on the port side, does the g6 pump system still allow for filling the left ballast?
