Once this is mounted I will have no way to adjust it. What are the most optimal settings for a pair of REV 10s.https://uploads.tapatalk-cdn.com/201...2dfaf201a2.jpg
Lots of variables that make it hard to ballpark the gain. These amps are notorious for the Hz POTS to be inaccurate, So thinking you have the dial set to 120Hz for example, it could be off 25Hz +/-. Makes it tough to set it on the bench and install the amp where you cant do a final run through by ear.
I’d like to say whatever I left it at but it was pushing a 410 lol
Get yourself a little right angle flat head or a pick set. It’s not ideal but it works. I had a hard time adjusting them once minted too
I started screwing with it unfortunately.
Going in a glove box so I just wanted to copy someone's set up.https://uploads.tapatalk-cdn.com/201...2e9e506a63.gif
